JDMrida wrote:I hooked up electric fans and I connected the positive to the Fuel Pump Fuse... after the fuse, not before it if you know what i mean.
Is this ok? This affects my car though. When I turn the car on, it stumbles a little. When I turn off the car, it takes 2 seconds before it turns off... I think it is because the fan is creating power to the fuel pump when it is winding down.
Thank you
The fuel pump fuse is only 15 amps if I remember, so don't be surprised if one day your car just "dies".
At least use a relay to the fuel pump fuse, or better yet, to the ignition, or even better, use an elecctric fan controller.
