electric fan issue
jdmser
Car: duh
I'm currently using a set of 12" electric pushers. I've been having a hard time getting the idle to stablelize and I think I know why. I turned the idle up after the car had been running for a while and it smoothed out alot. I went to get my emissions done and they wouldn't test me because the idle was to high. When I got home I turn the idle down and it start to surge again until I turned the fans off. I think the fans are just to much and drag the whole system down. I'm wondering if it would also be possible for them to pull enough current from the ignition system to give me a code 21. At any rate, I'll be installing a relay for the fuel pump to give it power strait from the battery. Whadda yah think.
nismopwr240
Car: RB20 240sx
You can upgrade to the quest 110A or 125A alternator.
ninety1two40
Car: 1991 240sx SE
I have the same issue. When my FAL dual 12" pullers turn on, the idle drops to 500-550 rpm and surges slightly. The fans pull to much current. I'll be upgrading to the Quest alternator in a couple weeks.
300Plus
Car: 1995 S14 w/ Rb25det Series II
FALs use too much amps from what I hear, permacools = more cfms and way less amps from what I understand
Carl H
permacool fans = fcking worthless.just put a quest alternator on there and be happy.
gawdzilla
Car: none
300Plus wrote:permacools = more cfms and way less amps from what I understand
http://home.satx.rr.com/nissan...t.htm
see conclusion 2.
FriedEGs
Car: 1995 SE, Roast Beef!!
interesting. I'm running 2 10" pushers from flex-a-lite, which work really well..
The manual says 18 draw, but i don't know if that is for each fan or for the total which leads down to a single power wire and single ground wire.. (factory wired parallel)
