red240ne wrote:you're wrong, i have a clutch fan.
Really. K, smart guy, I'm guessing you have a DOHC, look behind your fan shroud, in front of the clutch fan that YES, we all have too, and you'll see it. The SOHCs have a pusher fan in front of the condenser, DOHCs have a puller fan behind the radiator, in addition to the clutch fan. Comes on with the AC, or at low speed when engine coolant temp reaches 202 degrees, high speed at 212 degrees.
