Hey everyone. So I went to the junk yard to day and picked up some Maxima fans to install in my 240. (I couldn't find any Altima ones). Now as the wiring for these up I was planning on using the stock electric A/C fan plug like the guy did here.
http://www.240sxforums.com/forums/s14-2 ... -pics.html
I know I will have to change the plug out to work with the Maxima fan for it to work. One of my questions is if I do this when will this fan run? WIll it be on all the time or just when the AC is on. My second question is when wiring up the second fan I was planning on using a thermo switch. Something like this.
http://www.summitracing.com/parts/HDA-3653/
If I use this controller will I need to have another relay and fuse inline with the controller or will the relay that is built into the controller be sufficient protection?
Thanks in advanced.
