yes i have searched but im asking is there any other fuse that i can run..... i tried some of there fuses and they work the same as if u were to hook them up to the battery but they stay on all the time. is there any other fuse i can hook it up toojanda240sx wrote:1.Get a relay.2.Power the relay off of whatever you want.3.Run the power for the fan straight from the batt. through the relay adn to the fan4. SEARCH
Can you wire this kit up so that the second fan turns on when the AC turns on? And so that only one fan is on high or low, depending on temperature? am I asking too much from this kit?gmac708 wrote:I just put a Derale adjustable fan thermostat kit p/n 16759 ($39 at summit). It will turn on the fan only when adjusted temp is reached AND the ignition is on, and/or can be wired to come on when the A/C is running. It has a relay and fuse, so it can be wired directly to battery or battery bus. It also has output for dual fan as well.Check out the info at their web site.
nice rhymes. youre kinda wrong tho, champ.S13Teddy wrote:When you run it to the battery, the voltage is fourteen,I'm just trying to help, and not to be mean.Your fuel pump probably pushes two less,Therefore you will not encounter as much success.
