electric fan help!!
sr28
Car: 1990 240sx hatchback
so i just finished installing my electric fans with theromostatic snap switch on my s13 sr20
i grounded my battery to test it and the fans turned on...? no key in ignition.. just on constantly..
on the relay i followed instructions that came with it
black to groundbrown to snapswitchyellow... it says connect to any 12 volt key activated circuit. then to snapswitch ( i connected it to my ignition fuse) on the passenger side
green wire connect to the power wire leading to the a/c clutch. (i connected this one to the ac fan fuse wire)
red wire is connected directly to the battery like instructed
orange wire is connected to the fan
does anyone see anything wrong here? why does the fan turn on when the battery is connected??! helpp
MaximA32
The ignition fuse is always hot. You need to run the keyed power to your radio or the windshield wipers. Something that comes on only when the key is on.
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
1st off, what fan are u using..?? What thermostat and relay r u using..??
