electric fan fail...Help!
s13kcut
Car: s13 coupe
So my friend wired in my electric fan to my fuel pump relay directly to my fan. Then the 10 amp fuse blew. so he put in a 25 amp. Then next I know when the car starts driving is hot electrical smell. Then car died. Now my car wont start. Smells like its from the ecu. Could this have fried my ecu?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
you fried something. I cant believe you would put another fuse in there that didnt belong. you know those were put there for a reason right
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
What a stupid thing to do. This isn't KA related either.
str33tprintz
Car: 1996 Nissan 240sx SE
Damn that was dumb as hell, you probably fried your fuel pump, that fuse is there to protect it. I really doubt its your ECU but check and replace things in order cheapest to most expensive. Till the problem is fixed. So here's what you do.
1) Get a new fuel pump.
2) Install it.
3) Drive to your friends house.
4) Beat the S**T out of him.
5) Pat your self on the back for a job well done.
J14cm7
Car: 95 240sx S14 SR20det
This just goes to show you if you cant do something right dont do it at all
kanye240
Car: 1990 Nissan 240sx Coupe'^2001 jeep grand cherokee
Man, dont ever let someone work on your car unless you know they know what they're doing.And then still watch them ...lols
Research Research Research before attemping anything you dont know man
E-fan write upshttp://forums.nicoclub.com/zerothread?id=356228http://forums.nicoclub.com/zerothread?id=279510http://forums.nicoclub.com/zerothread?id=242562
Now go fix your car back to stock and retry and repost
Mangid
Car: 1990 240sx sr20 5-speed
That fan is gonna pull more than 25 amps... you needed a relay, numbnuts. Who knows what you fried now. If you don't know what a relay is, then you have no idea what the f*ck you're doing and you should have left the clutch fan on because it works better than whatever POS ebay fan you must have bought.
s13kcut
Car: s13 coupe
Yes i know what a relay is. Friend is currently residing in a shallow grave. Did trust him.....Mechanically, not electrically. And its a nissan maxima fan. But thanks. Hope you got your early morning anger out now....Took out ecu, opened it up....Its fried for sure.
