You wouldn't necessarily need a drastic change of look to let the heat escape. it will find its way through this setup: 5-10mm hood spacers (just enough to raise the hood without being very obvious,) wheel well vents for the intercooler, intercooler ducts, a 2500-3000CFM Efan, and proper radiator shrouding *on a larger radiator*..
A car travels forward 90% of the time, right? So you need a rearward facing vent, that's known. The vent need not be a large vent, but the larger the gap, the better the cooling. Thus removing the hood entirely will cool it better in theory.
You could go with a vented hood, but if water drips down on electrical wires, that can cause other issues and can eventually rust or corrode wires, you know. Some hood designs have this in mind, it's up to preference how you want to have your vent.
So hood spacers do the trick for people that don't want a vented hood.
This guy has the right idea with the hood spacers, but the FMIC is throwing heated ambient air at the radiator.
It's a pretty substantial gap once you factor in all 3 sides (rear, left and right fender,) that are now venting to the atmosphere and allowing a larger channel of hot air to move out of the engine bay (lol, and this type of vent isn't more efficient for drifters by the way, it's still an outward current type of vent.)
The main reason why mechanical fans were manufactured to push so much air is because not many cars came factory with vents for all this air to exit, thus a bigger fan is needed. And the rear gap is so large with a vented hood, it's more efficient at venting hot air than a mechanical fan is when it's forcing air out. More work is required on that end, which is why you lose horsepower.
So the bigger the vent, the less the fan needs to pull, (to a certain extent, you also need to factor in how much CFM at idle is required to keep coolant at normal operating temperature as well, which is about 2500-3000CFM.) The vent will naturally pull the air from the front of the radiator through the fan, then the fan guides it along it's course in the engine bay, and you don't even need a large fan to do that. It's the path of air. Eventually you're helping with aerodynamics as well, but that's another topic.
Think about it, this is why intercooler vents are needed inside your wheel wells, it's the same theory! You have all this air in the front bumper ready to push air out of the itnercoolers, but since theres a huge amount of stale air behind the intercoolers with no vent to escape that it prevents airair from replacing it, almost acting as a wall for cooler air to replace. This hotter air also rises in the bumper, which heats up the sides and the upper portion of the radiator core support, which essentially raises under hood temps and could also heat the radiator..
