:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Mar 02, 2006 5:13 am
I believe you use a 'sump' with that oil pump...so it'd drains from the turbo by GRAVITY, into a small collector...then the pump would pull the oil form the collector and pump it back into the motor (through the oil cap, or wherever).
The collector would need a breather so that you would NOT apply vacuum to the drain.
If you pull directly form the ruturn line, it will suck oil through the turbo, and kill it like WD's.
- Brian
