electric choke question
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
hey my choke works sumtimes and than doesnt others.....any ideas???is there any way to wire a switch in so i control it???
offroadbob
Car: 96 240sx, 84 720 4x4
just go to csk and get a manual choke cable and run it to the carb. just remove the electric assembly hook it up and go, pretty simple.
Charlie69
Car: 1966 Datsun 520
Make sure the wire that plugs onto the choke has a good tight connection. Sqeeze it slightly with pliers if the connector is loose or just replace the connector.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Charlie69 wrote:Make sure the wire that plugs onto the choke has a good tight connection. Sqeeze it slightly with pliers if the connector is loose or just replace the connector.
If this dosen't solve the problem, then offroadbob has the solution.
Return to “Datsun 720”
