FInally it is running. tune date in may. finishing the it over the next few months. Id like to make 500hp all day. Well see what happens.
Current parts:
r32 engine set
87mm wiseco piston
eagle rods
manley valves
manley valve springs & retainers
supertech bronze valve guides
tomei metal gasket set, 87mm by 1.5mm
tomei orifice
tomei fpr
fuel lab fuel filter
hks 272 step 1 cams and hks cam gears
hks gt2530 turbo w/ dumps and actuators
hks oil cap
new r33 crank
greddy intake plenum
tial BOV 50mm
power enterprise t-belt
splitfire coils
acl race main and rod bearings
apexi d-jetro intake
syko engine mounts
r33 gst-t crossmember
nissan N1 oil pump
nissan N1 water pump
nismo thermostat
nissan t-belt idlers
nissan factory gasket set
arp head and main studs
notched and welded rb26 oil pan
720cc greddy(denso) injectors
mishimoto radiator
mishimoto intercooler r-line
rb25 trans (rebuilt with new z32 parts)
nismo coppermix twin disc clutch
shaftmaster aluminun driveshaft
chase bays P/S kit
AEM ems series 1
defi turbo/oil temp/oil pressure/water temp gauges
AEM wideband
braille battery
evo 8 front brakes
powerslot front and rear rotors
z32 master cylinder
z32 rear brakes, r33 brake cables
z32 diff w/ j30 axles
stance lx+ coilovers
whiteline sway bars front and rear
whiteline control arm bushings
battle version RUCA
battle version rear toe arms
battle version tension rods
weds sa55m picture wheels 225/40/18 & 245/40/18
nismo lmgt4s track wheels 235/40/18 & 265/30/18 *r compound*
kouki taillights
memory fab kelvar bucket
takata harness
nrg short hub and quick release
nardi deep corn 330mm
r33 cluster
http://www.youtube.com/watch?v=umadeTWQcdk
There are probably things i have missed but who cares. Ill update when im done or just really bored. peace
