Hey,
Does anyone know what the Dimensions of the EJ20 or EJ25 are?I need the following dimensions:
Horizontal - Valve cover to valve coverVertical - Throttle body to Oil PanLength - Crank Pulley to Flywheel
The most important dimension I need is the Horizontal Width.
I know this can't fit in a S chassis.I've measured my S13 and from Frame rail to Frame Rail there is only 27.5 inches.
I've heard that the EJ DOHC engines are about 31 inches wide.
Also if anyone knows the Engine Bay Dimensions of the Impreza RS/WRX etc....
