eisest LIT sleepy eye mod
johntom
Car: 1991 240sx fastback
well to begin, just pull out the headlamp control switch and cut the brown wire, i used a swiss army knife because i couldnt fit snippers around the other wire.
step 2- now just turn your lights on and they will pop up all the way, turn off the lights and they will stay up (good job u cut the brown wire)
step 3-just quickly press the headlamp control button in and out until desired position is reached.
step 4, in your acessory fuse box (drivers side kick box) and pull the 5a fuse on the right side labled *light control*
conlusion- after pulling the fuse you can now turn your healights ON and still have them sleepy witch is much easier than buying a switch and wire tucking from the fuse box to the switch
p.s next time you want your healights all the way up again pop the 5a fuse back in and they are back in perfect working order
ashibah83
Car: 93 SUPA BLACK COUPE
im sorry i cant even read what you typed, your sig is to captivating...........
johntom
if you stare for more than 3 minutes you are officially straight
but otherwise, has this convinced any1 to go sleepy??
Modified by johntom at 1:11 PM 9/6/2009
EnjoiNismo
Car: 93 240sx
ashibah83 wrote:im sorry i cant even read what you typed, your sig is to captivating...........
There has been a lot of write up's on sleepy eyes.
Nali
Car: Datsun Nissan 280ZX
R
Nali
E
Nali
P
Nali
O
Nali
S
Nali
T
Stev0n
Car: 90 LS13.5 M6
08 HD Superglide 106ci M6
94 Ranger
97 mercury sable
96 Rape Van
seriously? do you have to use 6 posts to write repost? if you're trying to post whore with ignorant crap like that, could you at least do it in gen chat?
troskinatior
Car: A Two Tone Piggy Coupe
same thing happened to me haha
ectomorph
Car: 1990 240sx SE
weird...i think i messed up...i cut every wire BUT the brown one... ;]
Guam180
Car: 1991 240SX SE
johntom wrote:well to begin, just pull out the headlamp control switch and cut the brown wire, i used a swiss army knife because i couldnt fit snippers around the other wire.
Okay, question. What happens if I don't pull the light control fuse? Could I then use the light button for flipping the lights up and down? And the switch to turn the light on and off? Or will the headlights just keep popping back up when turned on?
Gcustoms
Car: 1992 240sx LE
sorry to tell ya, but first you spelled "easiest" wrong in the title (assuming that easiest was the word you were going for)second there has been a number of write ups on sleepy eyes, yours however contains no new information, maybe you should use the search button before posting something thats already been posted, idk.
usdm_anon
Car: 87 supra
thanks for telling us what we already know!
Cody240
Car: 1990 240sx SE white with KA24DE
IB4LT dude no there are like three million write ups on this I know that you had to have researched it Right? if not then please look up what you are thinking of posting rather than just posting something that has been covered. P.S I mean no offense to you just stating my opinion.
Kelbizzle
Car: 91 240SX SR20DET
I appreciate the post. Even though it's all over the internet. Someone may find YOUR post first. Or your post may show up in a search that only returns a few results.
Forget the haters! If information only existed in one place it would be very hard to get a hold of or to spread.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
johntom wrote:next time you want your healights all the way up again pop the 5a fuse back in and they are back in perfect working order
Well, I don't know about you, but I'm not gonna be pulling out and replacing a fuse everytime I either want sleepy eyes or wide awake eyes. It would be way easier to wire in a small switch in line on the fuse so you don't have to remove it, only flip the switch removing the fuse circuit from the headlight circuit. bam! Now it's the "easiest". But like said, REPOST!!!!!!
try searching. It's the icon on the top of every page that sais "SEARCH" and it has a magnifying glass on it with the nissan symbal in the glass. Yet another sleepy-eye write up to add to the pile....
BrianHarte
Car: 180sx
Is there a wire coming off the headlight switch STALK that you can cut to make the lights not pop up?
Is that the brown wire?
johntom
well, for your information, when you do start to loose visibility with your lit sleepy eyes( with the fuse out) just switch too your brights and they pop right up and will stay up if u switch back to low beams, and when u want them sleepy again put the fuse back, tap the headlight control switch in and out rapidly till they are where want em, pull the fuse out again and dont turn on the brights, and as for the wire being in the light signal stalk, thats not it, the brown wire is behind the headlight control button witch needs to be pulled out (carefully
BrianHarte
Car: 180sx
So there is no wire coming from the stalk that controls the movement of the headlight bucket? Seems like there would be...
keith0486
you sir fail for doing a write up on sleepy eyes im pretty sure if u did a search on google you will get millions of finds and about 4 million of them are here on nico.
