prlwhitecoupe »
https://forums.nicoclub.com/prlwhitecoupe-u68458.html
Wed Feb 04, 2009 2:53 pm
Nah man it's cool, they just didn't trim the boot like the instructions had told them too. It specifically mentions that in some cases the boot will have to be trimmed. But in my case though only one side had an issue, apparently the right side is just fine. Trust me, it's a good upgrade, but just be prepared to drive more cautiously around steep roads and large speed bumps, I've managed to hit the bottom of the car twice when not paying attention to a speed bump. Over time the springs will settle and the ride height will lower even more. At this point I think it's the perfect drop, for Canadian weather anyway, I don't know how anyone would be able to drive around in a car lower than mine with out constantly scraping over snow and ice, sometimes you just can't avoid it. But for the summer I wish I had coil-overs and drop it another inch or so and it would be perfect. But I'm happy with it so far. And if you want another huge improvement in handling you must get Stillen's rear-sway bar, it has significantly increased my handling and stiffness in the suspension. I also just installed Stillen's front strut bar but it hasn't given me as much as an improvement as the RSB did. It just makes the car seem a little more rigid in the front. I won't be able to tell for sure until summer comes around and I can hit the on/off ramps with some speed
