Eibach springs with 18" wheels
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
I have 18x9 rear & 18x8 wheels with 255/35 & 245/40 tires on my 96 Q45. I wanted to lower it a bit. Will I be able to use Eibach springs on my Q? I already purchased Tokico blue struts. Thanks. Mark
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
OUr admin, AZhitman has 18s on his Q with the eibachs, so your good to go!
Mark86T
Thanks, cuz I ordered them already. Someone else had told me they would work, but I figured it's better to double check before taking the time to install them & find out they don't fit.
Q45tech
Obviously Eibachs and Tokicko blue were designed against oem 15" wheel/tire weights [unsprung weight] so heavier weights will wear the shocks a little faster.
Mark86T
But they have to be better than the worn out factory fronts I have now. They are so floaty. My rear struts must have been replaced already-they are tight. The Tokicos have to be much cheaper than factory struts, even if they do wear out faster.
Q45tech
Same struts just that the blues [vs blacks] are valved 20% stiffer, to match the springs better.
Mark86T
That's what I'm looking for. More stiffness. What is the price difference between the black & blues? Thanks for all the info. It's great to finally find a place that can help me with my Q.
Blues are cheaper, you can buy at Southwest Autowoks (see ad to the left).
Welcome to NICO!!!
Mark86T
That site had nothing for Q45s.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Mark86T wrote:That site had nothing for Q45s.
Au contraire!They have Tokico Blues for G50s.
Call 'em up - Smoking prices on the blues.
Talk to Steve, tell him Greg from NICO sent you. Good guys there.
Mark86T
Thanks but I already bought my blues.
Ah - Well, you're gonna love the ride!
Mark86T
That's what I like to hear. If only my Eibachs would come in. Have the Tokico blues & I just put on 4 new slotted/cross drilled rotors along with my new 18" wheels & tires. Can't wait for those Eibachs.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Mark, beautiful car. Check out mine - love the silver paint.
Welcome to NICO!
The ride change is phenomonal, from worn out factory struts, to the Tokiko Blues.
I might suggest getting new upper links, and tension rods, as well as adding a Front Strut Tower Brace (check out the eBay special we have been doing).
I kinda "backed into" that one. I bought one for my wife's I30t, and just for kicks, tried it on my Q. In 45 minutes, it was on the Q, and I had to buy another one for the wife's car. They run anywhere from $1 to $15 on eBay.
It drastically tightens the front end.
You already have the rear stabilizer bar, so this will make a nice addition.
If you haven't gotten stainess steel brake lines, they really help pedal feel, and for around $100, it is a worth-while investment. I flushed my brake system, and went with DOT4 fluid.
I don't know if it helped, since I don't do any autocross, but I know when I go to North Carolina, that my brakes are much better than original, and with a 10.5" tire patch, I can stop much better.
Mark86T
Thanks. Your car looks great. For now I'm done with putting things into my Q. I have a Z31 turbo that needs my attention so I can get back to racing it. I did springs, struts, drilled rotors, wheels, tires, & stereo upgrades on my Q. I did regular mantainance such as transmission mount/fluid/filter, belts, fluids, plugs, thermostat, etc... It only had 53,000 miles when I bought it 8 months ago. I love the car!
Falkdesigns
Car: 1998 Q45t ~ EXE
Your car looks great. The springs will set it off just right. I looked at Jeff's car too and that is one clean Q! I ordered Tein's for mine today. Too bad it's gonna take nearly 2 months for them to arrive.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
What kind of stereo upgrade did you do?
Trust me, the $15 and hour of your time, will be well worth it, for that 2000 Maxima FSTB.:ylsuper It makes the steering feel like you took 2000# off the car!:ylsuper
The $110 I spent, on the SS brake lines, really firmed up the brake pedal. It took about 1 hour to flush the system and install the lines. The speed bleeders helped with the flush.
Mark86T
I put in a Sony head unit (CD/CDRW/MP3 player) with an adapter to keep my Bose speakers. I put a 10" sub in the trunk with an amp powering it. Great sound & even some bump.
Where do I get the Maxima front strut tower brace? Ebay? For what year Maxima? $15.00?!! Sounds too good (and cheap) to pass up. I will eventually put in the stainless brake lines, TT adj. tension rods & upper control arm links. But first I need to replace all the rear subframe bushings with urethane. One of the silicone ones is leaking.
Thanks for all the help/advice.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Mark, sounds like a great system.
Here is a thread, that has some pics in it, of my FSTB.
I have a good write-up, in Word format, with pictures that I can email you.
Send me a note, and I will reply: [email protected]
http://www.nissaninfiniticlub....53318
Better thread:
http://www.nissaninfiniticlub....=FSTB
EVEN BETTER thread:
Mark86T
Thanks for the links & info. Seems like a pretty easy mod to the bar to get it to work.
