Eibach springs on Ebay
blind6
Car: was a 1997 Infiniti Q45
Do these look like the right appliction for a 97Q? http://cgi.ebay.com/ebaymotors...QrdZ1
Good deal for new springs.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Bet they are for a Maxima since they start with 6311, although the current ones end with 140.
My FYG33 Eibachs from Duy are marked 6345.001 and 6345.002.
Just can't be for both FWD Maxima and the RWD Q45.
Modified by maxnix at 8:53 AM 12/27/2005
Raxephon
Car: '04 RX8...for the moment...
PRO-KIT 1.2 in 1.2 in 6311.140 (Taken from Eibach's website)
I was considering these for my '91 Q45.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
So, these are the correct springs for the 90-96 Q45? Nice price, so far...
I will not bid, if you want them.
Raxephon
Well if I could find some confirmation that these would work on my Q45 I'd bid on 'em.
At the moment I'm just waiting on a reply from the seller.
Raxephon
I downloaded the Eibach Catalog and this is what I came up with.
Modified by anlasak at 9:54 PM 12/27/2005
Raxephon
I bid on them
These should work on my G20 since I'm already running Maxima struts
bmwkiller
Car: '90 Q
blind6 wrote:Do these look like the right appliction for a 97Q?
The listing is through a 3rd party seller. I sent them an e'mail, and they replied with the following:
"The owner emailed me back with more info on the springs. Here is his email:To correctly answer the Springs question. The springs will fit 88-94 Nissan 240sx, 89-94 Nissan maxima. Unsure about the 90-94 Q45 they might fit but unsure."
I'm not sure where this info comes from. In the pic, the spring is stamped with the part number 6311.001. From what I've been able to find, the part number for the '88-'94 240sx is 6310.140, and the part number for the '89-'94 Maxima is 6311.140. The part number for the 90-96 Q is 6325.140.
Raxephon
bmwkiller wrote: The part number for the 90-96 Q is 6325.140.
Where did you get that part number?
It's not in the pdf catalog I downloaded from Eibach's website.
Rex
Car: None
anlasak wrote:Where did you get that part number?
If you Google Eibach 6325.140 and then check the "cached" versions of the results, you'll see that's the Pro-Kit spring for the 90-96 Q45. Most all the "active/current" links take you to dead or re-direct pages.
bmwkiller
Car: '90 Q
Yea, what he said. I googled 'eibach q45' and got a bunch of listings with that part numbers. I went through the whole ordering process a bunch of times only to get a message that says "the part number you requested is no longer available." The search continues.
bmwkiller
Car: '90 Q
maxnix wrote:Bet they are for a Maxima since they start with 6311, although the current ones end with 140.
I called Eibach. They confirmed that they are for the '89-94 Maxima. Appearantly their numbering system has changed.
