eibach springs installed problem
Strik3r69
Car: 2008 Nissan Altima 2.5s Coupe
So , i got my springs installed. It's been 3 weeks now and when i turn the steering wheel, It make a grinding noise. I have tighten the master bolts but sound still there?? Please help..
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Who did the install? From the sounds of it, sounds like you did...
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
Strik3r69 wrote:So , i got my springs installed. It's been 3 weeks now and when i turn the steering wheel, It make a grinding noise. I have tighten the master bolts but sound still there?? Please help..
do u have after market rims? Fat or 19s or 20s
Strik3r69
I had my friend installed it for me...and no..i'm still on stock wheels.
dldjros69
Car: 2012 Evo Gsr
Grinding, that stinks. I have no idea what could be rubbing. Does grinding = rubbing?
Chinaman
Car: 08 nissan altima coupe 3.5
didnt you check the front endlinks. those do pop out of place sometimes.
ESP
Car: 2008 SexyBlack A/C
Chinaman wrote:didnt you check the front endlinks. those do pop out of place sometimes.
That was my first thought too!
MorningViewCoupe
Car: Altima Coupe
I actually have the same problem.. Sound comes from the front end. Yes i do have 20's.. front is 225/35/20.. rubbing isnt the problem.. sounds more of a grind.
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
i have wide 20's with eibachs and no issues. slap your friend and take it somewhere and get um fixed.
MorningViewCoupe
Car: Altima Coupe
What could it be tho? I got mine installed at a well-known shop and still have this problem
Bmore-coupe
Car: 08 Altima Coupe 3.5
08altima35 wrote:i have wide 20's with eibachs and no issues. slap your friend and take it somewhere and get um fixed.
Viper5000
Car: 2009 Altima Coupe 3.5SE/6MT
If it only does it while moving I would maybe say motor mounts.....
charliejj
Car: 2008 altima coupe 3.5 MT dark slate
if it happens when turning the steering wheel, maybe the upper strut mount bearing is bad
Strik3r69
could it be the boot??
BigSlim_C
Car: 2007 Nissan Altima
I have that same problem. I want to know what it is before its too late and I have to start replacing things
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
hahaha i like that idea it made me laugh
toxik
Car: 09 Pearl White 370z
my front right wheel started making that noise as well. I'm thinking maybe its the bump stop? I didn't cut them, even though stillen instructions tell you to do it.
I'm glad I'm not the only one that has this issue though.
NJAltcoupe812
Car: black 2009 altima coupe
I found out its actually inside the strut itself. I had taken out the strut from the car and moved the internals around like it was turning with a wheel and its binding with something inside. I'm taking the spring off this weekend to see if it was the install or the strut
Calgary35SE
Car: 2008 Altima Coupe 3.5 SER
While were on this sort of topic i'm getting my springs installed monday and was wondering if i should get an allignment with it, the guy recomended but i'm not sure if its needed. Thanks, sorry to change topics a bit
shortys408
Car: '11 M37S
08 altima coupe 2.5s - *Sold*
an alignment is 100% needed
