Lt.Mike »
https://forums.nicoclub.com/lt-mike-u20681.html
Mon May 02, 2005 1:03 pm
I have Koni's and they are awesome. They are a PITA to install, but totally worth it. They also have Lifetime Waranty as long as you have the receipt and still the owner of the car.
I have Pro-kits also, and they are pretty decent. Track wise, you should use linear spring rates rather than progressive spring rates. AGX's are pretty good if your car is going to be a daily driver and their adjustablity for all the struts is pretty easy to do. For the Koni's, the rear can only be adjusted when they are off the car.
Hope this helps, and search for installation for Koni's if you choose to get them. The AGX's are a simple bolt on bolt off thing.
By the way, replace your strut nuts while you are at it, and if your upper strut mounts are tearing, I suggest replacing those as well.
