ur always lost... i got one for you go do some work and get of the forums... ur a bad bad man u ate all my cheese always eating my cheese and never replacing it drinking all the Snapple in the house WHAT A D I C K .....WADtoxik wrote:I'm really lost at this point. You guys have any suggestions on what I can do?
yeah, it wasn't your average stealership tech. the tech was brian's (lbc) personal friend who happens to be a tech at a nissan dealership. he told me he took it apart 3 times due to the noise still being there, so I'm 100% sure his inspection was correct. The whole strut assembly was replaced, and from the sound of your problem, I think he would of noticed the endlinks being defective if they were causing the noise. The strut actually vibrates when you turn the wheel, I'm not sure if the endlinks could be causing that.ESP wrote:I had a similar sounding problem, but it was caused by my front endlink which had come apart...when I turned the wheel at slow speeds, it would gouge the wheel liner making a horrible grinding noise. If the stealership did in fact replace the strut though, this should have been taken care of.
Did the tech explain exactly what the noise was coming from, or was it simply "it's the spring" and left it at that?
No way man. I don't think anyone is saying that Eibach makes a s*** product...If it is indeed a faulty part, then it's likely just an isolated incident. Most of us are running Eibach springs and some of us have been doing so for nearly two years.blackteam02 wrote:whaaaa?? Eibach = garbage?!?! and stillen is selling them??
do the part numbers match up on all 4 springs? maybe one is the wrong spring.
damn, and here i was going to order the eibachs this weekend too!wow
ye i heard that racingline endlinks cause some people problems and you have to put sometype of substance on them so they dont snap out of place or something. Anyways, seems like I might be adding to my problems if I get em lol. If I see someone selling them for cheap, THEN I'll get em heh.Ricko wrote:Oh, your on stock endlinks? I was under the impression you already had racingline ends.
Still try and diagnose the issue first. Then invest in endlinks
the opposite, I don't hear it when I'm driving only when I'm stopped or barely moving (not hitting the gas) so basically if I'm yielding to make a left turn or parking and have to turn the wheel to the left.bunda4th wrote:It would be strange how the spring would make noise from turning. I say have someone outside as you turn the wheel to actually see if anything is hitting or bounce the car from outside to make the spring compress a bit and see if the noise is there.
Does the noise only happen when you are driving? Are you able to hear the noise when you turn the wheel at a stop?
The nissan tech told me that he could actually feel the the strut vibrate when the noise was being made. So I'm not sure if the sleeves are the cause of the noise.kyle@stillen wrote:Did you get a chance to take a look at the spring when it was disassembled?
Sometimes the powder coating can wear off a little bit and can begin to squeak or grind on the top mounting plate.
There are two ways to fix this.
1) Turn up the volume and live with it.
2) (more seriously) take a look at your factory springs. If memory serves me correctly there might be a greyish colored rubber or plastic sleeve that is covering the spring. This is to prevent the squeak I'm talking about. Sometimes you can remove that sleeve and put it onto the Eibach springs.
It sounds to me like the spring is floating a little bit inside the shock. This can happen and is pretty normal for any vehicle, with or without a lowering kit. Which is why the O.E. manufacturers generally put these little rubber sleeves on their coil springs.
I know EXACTLY what kyle is talking about, i put mine on the eibachs.. its like a clear plastic wire covering that goes on the coil...kyle@stillen wrote:Did you get a chance to take a look at the spring when it was disassembled?
I remember the rubber cover on eibachs, I put them on with a friend. But the oem springs didn't have any rubber cover on them...kyle@stillen wrote:I don't really have the ability to do a close up shot of our install because our Altima Coupe is currently on display in our showroom so I can't exactly whip a wheel off and get in there. But I did a quick google search and fortunately was able to find a picture that will help. Please ignore the fact that this is for a Subaru WRX STI. The idea is the same for any vehicle.
http://home.comcast.net/~fabio...g.jpg
In this photo you can clearly see the rubber cover that is going around the spring. This cover is designed to rest between the spring and the mount to prevent any of these squeaks or rattles.
