eibach pro-kit vs sportline
methodchris
pro's / con's to either of these? trying to decide which to get , tryed searching but couldnt find a good thread.
clearview
i have had pros w' tokico blues on my 95 since 1998 and have about 70k on them. i am pleased with the setup. i did have to put a whiteline rear camber kit in because lowering gave me too much negitive camber.
aaronsnocker1
Car: 93 240sx
where did you get your whiteline rear camber kit?
Phax
Car: Control dynamics
I went with the ProKit after I removed my kg/mm DR21 SuperSport, mad tyte JDM drift-springs, y0. Combined with Bilstein sport struts, the car sits pretty near stock height and handles the freeways and daily abuse that I subject my chassis to.
The progressive spring takes a little while to get used to. Yet now that I understand how it absorbs high speed bumps and what not, I kind of like it. Keep in mind, if you were on a race track, you wouldn't want something so soft. Yet for the street, it's a well tuned spring.
I was wary of going with the Sportlines because of the drop. 2+ inches is a little too aggressive for some of the roads around here. Though with the right shock, you might be able to get a good ride out of them.
clearview
i got the camber kit from PDM . pdm-racing.com this site has lots of stuff for the 240. i have dealt with them many times.
L0sT
Phax? where did you get your bilsteins from?
