Eibach Pro Kit VS H&R sport spring set
All things Altima Coupe.
white midori
Car: Altima Coupe 3.5 SE 6M
Hi Can anyone give some comments between these 2 springs , I know H&R can be lower the coupe a bit , but beside this , any other different between these 2 springs that i need to know .
Thanks every one
terrycs
white midori wrote:Hi Can anyone give some comments between these 2 springs , I know H&R can be lower the coupe a bit , but beside this , any other different between these 2 springs that i need to know .
Thanks every one
H&R seemed to shortcut some R&D in the past by using existing part numbers on new model cars. I noticed this was the case with their G35/G37 which shared the same part numbers between first and second gen cars.
Eibach specifically does R&D on each car so the ride heights are similar from one model year to the next.
Like you said, H&R also tends to lower cars a little more than Eibach Pros. Other than that, they both seem to do the job.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
WHEELS AND SUSPENSION AREA HAS ALL THIS INFO!
