Eibach pro kit & tire wear...
skim35
Car: Infiniti M37 Sport
Hi Anyone out there having uneven tire wear with there eibach pro-kit?I have a 06 M35 sport (stock). Debeting on either Saving $ and getting the Eibach $200, but tire wear, camber?? OR Megan coilovers $900. Any advice...
thanksSkim350
jankenpo30
I think your typical response is going to be if you drive like bat of hell and constantly want to change your setup, coilovers.
If you are going for lowered look, aren't going to change it, & just daily average driver, springs.
Either way, proper aligning and pressure will always be the key to tire wear.
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
No sure if I qualify to answer your question since I drive the previous body 2003 M45, but since I installed my eibachs back in Jan 2006 I haven’t had any un-even tire wear, but driving habits will be key. I also drive my car like an elderly man. Also, if you fail to get the perfect alignment you will suffer some tire damage.
Grantbo
Car: 2006 M45 Sport
skim35 wrote:Hi Anyone out there having uneven tire wear with there eibach pro-kit?I have a 06 M35 sport (stock). Debeting on either Saving $ and getting the Eibach $200, but tire wear, camber?? OR Megan coilovers $900. Any advice...
thanksSkim350
Eibach Pros are designed to work in conjunction with OE shocks/struts and the resulting drop should have minimal impact on your camber, thus minimal impact on tire wear. Drops greater than the Pros definately require camber adjustments. Being new to the Infiniti world, I don't now if the after-market has camber adjusting plates like the Bimmer world does. As someone said, springs only will help tighten up the ride a bit and eliminate gaps, whereas coilovers are designed to help you dial in the car for track situations.
Q45tech
Suspension and all its components only represent <10% of handling the other >90% comes from tires.
Radical springs and shocks cannot change things even 4% as measured on a skid pad or slalom from ideal oem settings.
Grantbo
Car: 2006 M45 Sport
Q45tech wrote:Suspension and all its components only represent <10% of handling the other >90% comes from tires.
I agree, and it's that meager 4% that every racer spends $$$ trying to dial in.
Modified by Grantbo at 2:29 PM 5/22/2008
skim35
Thanks you all for the infoLooking more towards the eibachs since they are cheaper and will give the lowered stance i am looking for, just hope the tire wear isnt too bad..?I do drive normal to a little spirited at times. Also I am looking into getting new rims most likely 19's maybe 20's staggered. when that happens will I need to redue the alignment....?
thanksskim350
jankenpo30
Of course....always align new wheels. no brainer.
auditech10
Car: 03 M45
Changing tire sizes does not affect the alignment settings AT ALL. But it is common practice to recommend an alignment when going from worn/uneven tires to new ones.Cheers
