Eibach Pro Kit
lucas
Car: 2008 nissan altima 3.5 SE coupe
Had local shop install lowering springs . looks good . After about 3000 miles front springs started making grinding sound. Returned to shop and was told that springs are twisting due to factory struts and I need to get lowering struts. Is this correct? If so which struts are recommended.thanks lucas
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome Lucas!
THis is in the wrong section, but i wont move it to the suspension area, just because i want to make sure you can find it.
All i think needs to be done is tightening the Master Strut Nut....
This issue has occurred to several of the guys here, and once you tighten it up, you should be sittin pretty!
