Eibach Pro-Kit Lowering Springs - Comparison Pics
All things Altima Coupe.
leifab
Car: 2011 370z Touring sport
My Eibachs came into today and got them installed. Here are the comparison shots.
****EDIT****
And for all those who said it couldn't be done, check out the rear camber.(yes i know it says 2005..they didnt have a 2008 in their system..but its the numbers that are the important thing)
Modified by leifab at 8:03 PM 4/16/2008
Modified by leifab at 8:04 PM 4/16/2008
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Much better!
bembol
Car: 2015 Nissan Murano SL AWD Cashmere Interior
Love the Drop & Tint.
Thanks for the Pics.
mhm1170
Car: 20008 Altima coupe
The drop looks great..............
I am thinking of doing the same thing but have a few concerns that maybe some of you can answer for me, before I make my decision.
1. I called stillen today about a camber kit for the 2008 3.5 altima coupe. they have not yet seen one come out, so my question?.......... are you guys seeing extensive tire wear?
2. Any squeaks coming from the new spring prior to lowering your car?....
3. I am running 20" wheels....... those of you with 20" wheels, any rubbing?
4. Road noise ?....... did the road noise increase much with the drop ?............
5. Ride ?........... about the same as before?........... or worse?
Thanks you guys any input would be welcome.
Mike
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Looks good man
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
mhm1170 wrote:The drop looks great..............
1. I called stillen today about a camber kit for the 2008 3.5 altima coupe. they have not yet seen one come out, so my question?.......... are you guys seeing extensive tire wear? I PROBABLY PUT MORE MILES ON MY CAR THAN ANYONE WITH THE DROP... NO ISSUES WITH TIRE WEAR
2. Any squeaks coming from the new spring prior to lowering your car?.... NO
3. I am running 20" wheels....... those of you with 20" wheels, any rubbing? ITS NOT THE SIZE OF THE WHEEL, RATHER THE OFFSET/WIDTH THAT CAUSES IT.. IM ON 245/35/20 +38 WITH no rubS
4. Road noise ?....... did the road noise increase much with the drop ? SLIGHTLY, BUT MY BIG TIRES ACCOUNT FOR MOST OF IT
5. Ride ?........... about the same as before?.sAME? HAHAHA.. 3X BETTER!
Mike
leifab
Mike
1. Look at the rear camber on my readout sheet. It is possible to get it within spec without the use of a camber kit. My mechanic said that if some one couldn't, it's only because they don't know there way around the end of a wrench.
2. No squeeks so far, but they've only been on a few days now. What i do notice now is every single bump in the road, no matter how small.
3. I got stockers...will prolly never roll with 20's
4. Zero increase of road noise.
5. Ride feels ALOT tighter when turning, but again i stress that i feel every single bump in the road. The lifting of the front end on launch and hard acceleration has all but been eliminated.
These are my impressions...your mileage may vary.
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
Sounds right on the money.
mhm1170
Thanks for the feed back.............. Every thing sounded good up to where you said.................. you now feel every little bump in the road. not what I had in mind with the lower springs, I just might have to pass on this mod.
Any other feed backs ?............ come on guys I know lots of you have done this, lets here from you. I really like the looks of the drop but do not want to sacrifice the ride with having to feel every little bump on the road. Also, I would like to hear more feed back from those of you who have 20" wheel with the eibach pro kit.
Thanks everyoneMike
Canadian Coupe
Car: '07 Saab 93 Turbocharged / Soon '09 G37 or '09 A/C
mhm1170 wrote:Thanks for the feed back.............. Every thing sounded good up to where you said.................. you now feel every little bump in the road. not what I had in mind with the lower springs, I just might have to pass on this mod.
Thanks everyoneMike
Same.
I don't want to sacrifice that much ride quality. Especially since I'm going to be putting 19" rims on my Coupe.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
That sheet really has no credibility though. Its not the over/under numbers developed to represent the a/c, those numbers are programmed for a 4 door, heavier car. Weight distribution and camber are going to be affected differently.
leifab
I know the over under numbers aren't gonna be accurate, but if you look at the actual value's of the rear camber (-0.9 and -1.0 degrees) you'll see that it's possible to have the drop done without affect camber too much. That's all I was trying to point out.
tuffmag
Car: 2008 Winter Frost, Altima coupe 3.5SE CVT, Premium, Technology Package
Ok, ok…I did the Eibach-Pro upgrade and here are my immediate findings. Remember I came from a “Mini Cooper S” riding perspective, and with that car you hear every road noise, every bump and even the small pebble. Ok so why am I saying this. According to members…mhm1170, and leifab .. they were concerned about road noise and ride..
Well compared to the Mini cooper, the Altima ride is still by far much better even with the drop. The ride in general is fantastic. Handling is better but only had it for less than 100 miles for driving. I will give better report once I get the springs settled. So, anyone thinking about the drop and the ride…Just DO IT>>>
mhm1170
Thanks tuffmag............. what size wheels are you running?.........
LongBeachCoupe
2005 Lexus RX
ive got a few thousand miles on my eibachs... all i can say is ohhh da baby! such a sweet ride, i cant wait for my rsb (shipped yesterday) to compliment it! I truly feel for those who missed out on the GB!
tuffmag
mhm1170 wrote:Thanks tuffmag............. what size wheels are you running?.........
Stock wheels and tires on the beast for now, but plan to move up to 18 after I get my suspension done.
mhm1170
rsb ?..............wht does rsb stand for?...... just out of curiosity, what was the group buy price. I just received my eibach pro kit from the tire rack............. $212.00 no sales tax 19.00 shipping total came out to $231.00
Tuffmag, I am running 20" wheels with 245/35/20 tires, the ride is not bad at all considering the 20" wheels but I really don't want it to get any worse with the eibach pro kit. I am thinking about just dropping the front end 1.5" to see how it looks and feels/drives.
Any one out there have any thought on just dropping the front end and leaving the rear with the stock springs?.......... to me, the front end looks higher then the rear, I just measured.................... the front end is definitely higher.
Mike
leifab
RSB = Rear sway bar
mhm1170
Ok..... thanks
tuffmag
mhm1170 wrote:Tuffmag, I am running 20" wheels with 245/35/20 tires, the ride is not bad at all considering the 20" wheels but I really don't want it to get any worse with the eibach pro kit. I am thinking about just dropping the front end 1.5" to see how it looks and feels/drives.
Mike
after about 75 miles i found the ride to be much more responsive. there is no longer the dive when applied brakes hard, and the acceleration issue with the front end is gone. Update on the feeling of the road has not changed. It is a little bit stiffer in the ride but a trade off that is well worth it in the curves.
So, IMHO have the drop was a great move on my part. Now for the next step with the RSB...
