eibach lower springs for 03 M45
tbl178
Car: 03 M45, 02 S2000
i just found a place to buy springs for m45. is anyone interested?
auditech10
Car: 03 M45
where
caug1
Car: 03 M45
yes please.do i need the bumpsteer kit too.
tbl178 wrote:i just found a place to buy springs for m45. is anyone interested?
auditech10
Car: 03 M45
....... and then he dissappears.......
ProvidenceLeaf
Car: 2003 M45
I'm in! Where?!?!
eskay
I got Eibach's last week at Adolph's dealer supply. They had ONE set on their shelves!!!!!!!!! I literally called 20-30 places and what finally panned out was when I called Eibach, the rep gave me the most recent shops taht ordered the Pro Kit's 6371's. I called the first three, and Adolph's happened to have them on their shelves. I guess I was REAL lucky. They cost $223.00 shipped!!!!! Good luck everybody
caug
i give you double for them. joking.do we know rates on the spring at all?how much stiffer are they then stock ?any time when you lower the car you need to get the bumpsteer kit . any idea?post some photos you lucky guy.can we call you lucky?
auditech10
Car: 03 M45
Bumpsteer kit, why?
eskay
No kit needed. Pro kit's do not require them. I need some warranty work done on the suspenson of my car, so I am not going to install the springs until after that is done. So the dealer does not have an excuse to not warranty the repair. I suggest you call Eibach and have them tell you which dealers have actually purchased the 6371's recently, then call the shop directly. It's a long shot, but WORKED FOR ME!
caug1
Car: 03 M45
for the proper functioning of the steering rack's tierods needs to be paralle to the ground . thats with the stock hight. so when you are lowering car an inch your tierods will go up an inch. thats not right functioning streering. thats when bumpsreer kit comes in. i dont know why it is called that way. but if you call any performance shop they will help you to understand my broken english better for you.i hope i explained it right.later.
eskay
There are many websites that show the 6371 Eibach's on their site, but they have to actually ORDER them through Eibach, which no longer carries them anymore. You have to find a dealer that has them on their shelves physically. Make sure they say 6371. Good Luck
eskay
I had Eibach Pro Kit's on my 97 Supra TT w/ KYB shocks. No bumpersteer kit, camber kit, or any other kit needed. The car aligned fine, and drove fine for 150,000 miles. No problems.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You did well.
Eibach drop may not be enough to cause a problem like the JDM belly scrapers.
caug1
Car: 03 M45
i think i am using bumpsteers kit as you are using eibach kit for the same thing.all i know that when car lowered it mess up the steering rack so tierods need ajdjuastment. tierods needs to be parallel to the ground to work right.
eskay wrote:I had Eibach Pro Kit's on my 97 Supra TT w/ KYB shocks. No bumpersteer kit, camber kit, or any other kit needed. The car aligned fine, and drove fine for 150,000 miles. No problems.
auditech10
Car: 03 M45
Bumpsteer is just what it sounds like, when you hit a bump the car tends to want to change direction somewhat. Basically adjusting the "raised toe", which is what the alignment machine calls it, I believe it centers the tie rod to a middle point that will reduce this change to a minimum. Tie rods, inner and outer, are just like your driveshafts on a non solid axle. They flex to keep the connection instead of being on solid piece. In extreme conditions like slamming the car on bags there would be a need to somewhat change the angle the tie rods are sitting. But lowering the car will not keep them from doing what they do.
excluesiveonez
can someone post a pic of the suspension components (front and rear) of their m45? i guess a pic with the wheels off
M35Man
Car: Acura MDX
http://www.stillen.com
They say they have them in stock.
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
M35Man wrote:http://www.stillen.com
Naw Naw, let me pull you from the fire before these Y34 guys get to you.They only have it for the newer M's, not the 2003-2004. I called and gave him the part number of 6371.140 and he said, "No" , but good looking out man
M35Man
Car: Acura MDX
[QUOTE=CakeDaddy]Naw Naw, let me pull you from the fire before these Y34 guys get to you.They only have it for the newer M's, not the 2003-2004. I called and gave him the part number of 6371.140 and he said, "No" , but good looking out man[/QUOTE
Thanks for the info. I was on their website and it didn't dawn on my that I was looking at the 2006 models.
pedros94probegt
Car: 2003 M45, 1994 Probe GT, 1992 Civic DX, 2005 R6
tie rods are designed to move up and down with ur suspension. your car lowers and raises all the time as it moves down the street. if tie rods had to be parallel to the ground all the time than any time u would go over a hump in the road going around a turn ur steering would get messed up. he may effect his camber...but im assuming he'll end up with 1" drop around...so its very minimal. m45 suspension has stock camber adjustments on them so all he really needs to do is at most get an alignment after.
bishop1
I just received my eibach pro kit 6371.140 today. I got it from import replacement parts.com for $254.61. They did'nt have it in stock they ordered the kit from eibach if you call eibach they may tell you they don't make them anymore but ask them to check the warehouse. Good luck!
auditech10
Car: 03 M45
Wow, and to think of all the people that did that same exact thing. Maybe theres some liars here trying be the real exclusive ones, lol.Good find you are one of the few with EibachsCheers
CakeDaddy
auditech10 wrote:Wow, and to think of all the people that did that same exact thing. Maybe theres some liars here trying be the real exclusive ones, lol.Good find you are one of the few with EibachsCheers
sweet!! get'em while they are hot!
bishop1,
good looking out my friend and Audi was correct, many people have ask the same thing from Eibach, but to no avail. It sounds like the good folks at Eibach need to get up and go do some real foot work through that warehouse of theirs.
