Eibach Install........need some help
smmehdiz
Car: Altima Coupe 3.5 SE 6spd
hey guys,
i did check over the how-to's and i couldnt find anything in the posts so i'm posing my problem here........
i have installed the front springs and we have put the car back down on its tires...but, when we try to re-tighten strut from the engine bay, the "strut shaft"??? keeps turning
if i'm not mistaken, you cant really put anything on it for fear of damage, and allen wrench/wrench combo tightens it but not enough to prevent suspension noise
help!?!?!?!?
alphapig
Car: Nissan Altima Coupe S 2.5
On top of the strut there is the master bolt, which you are trying to tighten.
Inside of that bolt is a star shaped socket (whatever they are called)
You need to get a screw driver into that socket and hold it in place while tightening the master bolt. This way the whole shaft will not spin.
Questions?
Altima_Coupe
Car: 08 Altima Coupe 3.5se
...yea, what he said^^^
alphapig
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
torx
alphapig
^ Yeah! There you go, I knew it was some strange name.
Smmehdiz give an update so we know you got it working...
smmehdiz
i'm going to be trying it again saturday when i can use my friends garage.....he doesnt come back til then so i'll let you know, but i've also been told that a 6mm allen socket could to the trick too?
SlammedAC08
Car: 2008 Altima Coupe
had the same problem when i did mine. you have to jack it back up just high enough so u can fit your hand in the wheel well. then lift the dust boot up and hold the shaft while someone tightens it....
