Eibach Help ?!
RishTheDish
Car: 2010 Alitima 2.5 Coupe
So two days ago I installes the ProKit and now I am noticing an odd noise from my front driverside wheel well. From the inside sounds like a low pitch "whob" sound, while from outside is slightly more of a higher pitched sound. The odd part; this noise is only produced when there is no throttle/ acceleration or breaking being applied.... anyone got ideas?
superbad
Car: 2014 alti 3.5SL
Did you check to make sure everything is tightened properly?
Or the spring is sitting properly and not upside down?
Have video of noise? Usually helps better
RishTheDish
During lunch break today I threw it up on the lift to check it out. Everything was nice and snug and seated properly.... put the wheel back on and drove out and it was fine. No more noise... makes me wonder if the lugs hadn't been properly tightened. In anycase, all is well now. Now what mod to do next?... decisions decisions...
RicerX
Car: '20 Titan Pro4X
You might not have had the wheel seated properly and tightened it down that way.
I would inspect the hub to ensure you didn't bend or damage anything.
As far as your next mod - some wheels to go with the drop. Bam.
