Eibach help
All things Altima Coupe.
migs7585
Car: 08 Altima Coupe 2.5s Super Black
Ok so me and my brother in-law did my Eibach springs, no problem except i'm getting a jiggle from the front passenger side. Maybe something is loose?? I'm wondering if it is the strut bolts? I tightened them but the middle big one just keep turning...
GrayCoupe
Car: Altima Coupe 3.5
I suggest that you take the strut off, compress it, and tighten the middle bolt correcty then install it.
how many threads can you see on that strut bolt over the nut?
soxypoo
Car: 2008 Nissan Altima Coupe 3.5 ( gone )
2010 red G37X w/sportpackage
2012 sentra ser spec v loaded
ya tight the strut bolt , atleast 3 or 4 threads show on mine
migs7585
I tried to tighten it again but still. Were gona take it apart tomorrow and put it back together, see if that helps. Is it ok to drive like that for now?
GrayCoupe
On mine it's showing 7-8 threads make sure that is correctly tight to avoid a loose strut.
Another way to check for noises and correct tightness is to open up the hood and press down the car a couple of times from the chassis corner of the suspicious strut and see if the bolt and nut move up and cause a clanking noise.
migs7585
GrayCoupe wrote:On mine it's showing 7-8 threads make sure that is correctly tight to avoid a loose strut.
....good idea, thanx
migs7585
7 threads on both, you can tell other bolts arnt where they were originally though....driving around like this a problem?
migs7585
Fixed it people....thanx for all the help...it was the strut bolt, just needed an extra umph...my and my uncle did it ol school with a copper pipe to extend the ratchet and use leverage.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
migs7585 wrote:my and my uncle did it ol school with a copper pipe to extend the ratchet and use leverage.
Nice...
