m-licious wrote:wheel size can play an important role. if your wheel is too big or wide or offset too low, you may have to dial in neg camber to avoid rubbing.on the other hand, i'm rolling stock 18" rims and still have neg camber with the eibachs. this is not due to rubbing concerns exactly, but more due to the geometry of the rear suspension. there is a lower tension arm/control arm that due to the lowering of the car, forces neg camber.
in Eibach's defense, the car looks great and the ride is not bad at all. in fact, other than rare clearance issues on huge speed bumps, i can hardly feel a harshness difference from stock and the drastic change in roll and pitch is appreciated.
That's a perfect description.
Altering a key suspension component is going to have a ripple effect. The increase in camber also adds about +2* of caster. The caster increase has a positive impact on highway stability. Trambling concerns are almost completely resolved.
The Eibachs tell you in the installation instructions that they tires should be rotated every 3k after the spring install. Cross rotation will also greatly increase the longevity and even the wear out over the full contact patch.
There is no possible way that anyone will ever be able to zero the camber in the rear with the factory eccentrics. I'm betting you will not be able to get any closer that -1.75 although that is pure speculation as no two Ms travel the same roads meaning the wear is different. I have not seen any adjustable control arms for the front or rear but they may exist.
The front camber is not adjustable from the factory and I can imagine that running rims over 20" would rub on something, and they will transfer more road imperfections. Something about increased rotational mass and decreased sidewall shock absorbing capabilities. That is a personal choice though.
