Eibach camber kit released?
All things Altima Coupe.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
As the title says, are these a camber kit for our cars?
http://www.tirerack.com/suspen...d=all
$26 for the front and $49 for the rears
mcheddadi
Car: R8
WOW! FINALLY! should do wonders in the rear with the coilovers
nig1
Car: 2010 Altima Coupe 2.5S
saw these a while back. Not really needed if u have pro-kits.
Oilsink
Car: 08 dark slate
the rears only have toe adjustments, the fronts do allow for camber adjustment tho.
crayzitalian3
Car: 2007 Nissan Altima 2.5S
if these get rid of any camber, would we see any difference in handling?
Oilsink
Car: 08 dark slate
Negative rear camber is actually better for handling.
ItsEcko06
these have actually been out from engalls for a while now. i have some laying around at my house, got them maybe a year ago.
crayzitalian3
yeah, i knew rear camber was better, but I just wanted to ask anyways just to see if someone says "oh its better to install these bla bla bla" just looking for opinions
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Oilsink wrote:Negative rear camber is actually better for handling.
a little camber but not a lot. A negative camber of .5 is good as this allows more tire surface area on the road.
BamaCoupe
Car: 2011 G37 Coupe
Just got my Eibach springs in the mail yesterday; how essential are these chamber kits with springs? What exactly does a chamber kit do; is it for better alignment, and if so can they (tire shop) not properly align without this chamber kit and I'd be sacrificing tire life?
Blackmobile
camber kits will fix any camber issues you have after installing springs. when you lower your car it will usually give you a bit of camber. some people have had no problems with getting an alignment to get the camber back to spec but others not so lucky. with the kit you can also manipulate your camber to the way you want it to a degree.
devilmagic
Car: 2009 Nissan Altima Coupe 2.5
Blackmobile wrote:camber kits will fix any camber issues you have after installing springs. when you lower your car it will usually give you a bit of camber. some people have had no problems with getting an alignment to get the camber back to spec but others not so lucky. with the kit you can also manipulate your camber to the way you want it to a degree.
Recently my car has been pulling to the left after 2 alignment check the tech suggest me install these Camber kit. He told me just order 1 camber kit, that i dont need to order in pairs. Any suggestion whether i should order in pair and install both or do as recommended just install one side. Thanks
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
Ok yes BUT you deff won't need these if you only have springs. The only way ude need this is if you hav e coils and slam it. Even if you have coils and don't slam it an alignment is all you need then. So to answer your ? Your ok no worries
johnnir3volution
Car: 09 nissan altima
Our cars can actually use the Gs and Zs camber arms insteal. With these bolts you would have to elongate(drill) the hole to get these to fit
devilmagic
i talk to the tech at my local firestone he told me to further adjust my camber (for me to drive straight) i would need to install a camber kit, price 90$ include labor..
downedzephyr
Car: 09 Altima Coupe 3.5se
just get z adjustable camber arms. $100, self install, way better than camber bolts.
SanoSuKe
Any feedback on these? Anyone got to install them?
AltimusPr1me
Car: 08 Altima coupe 2.5
just curious. If im having problems with alignment on my 08 altima coupe would camber kit help me get in spec. all that is done is instead of stock 16 inch wheels I got 18 inch. bc im having a problem getting my car aligned to spec and curious if camber kit would solve my problem?
