Darius wrote:I'm assuming you can run the wideband signal and EGT signal to the standalone ECU. Is that correct? Also, did you guys order their LCD display unit or just wire the sensors into your ECU? It's an extra $120 for the LCD and I already have a PFC w/hand controller, so I'd like to avoid buying that if I don't have to.
I'm thinking of just installing the EGT sensor while I have the motor apart and then buying the wideband once I get the motor running and broken in.
the zeitronix has a 0-5V wbo2 output that you can plug into your EMS, but the PFC itself doesnt accept voltage inputs. you need to get the FC-datalogit box to take inputs. If not, the best you can really do is look at the wbo2 numbers/log them on your laptop using the provided zeitronix software. OR you can input your tps, rpm from your PFC into the zeitronix box and see those values in conjunction w/ wbo2 in the zeitronix software. however, that wont correlate directly with any of your 20x20 cells in PFC. best bet really is to get the datalogit box if you want to do your own tuning. otherwise you need to rely on tuners that have the apex software or datalogit. the commander is really only a monitoring device and a very gross adjustment tuner.
The EGT you cannot output. you simply view/log that one in the software.
I don't have the $120 lcd display either.
now someone answer my EGT question at the top
