deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Mar 22, 2004 8:46 pm
Do you think there would be much difference between any of the 4?, seeing as its a single throttle body system (similar air flow to all cylinders). I know with any kind of individual system temps could vary. This involves installing some sort of a bung in the header correct?, im assuming you are running an aftermarket header. Installing one nicely in a cast manifold would seem a bit tricky with out making a weak crack prone area.
but then again, i could very well be wrong.
