msaskin »
https://forums.nicoclub.com/msaskin-u13754.html
Tue May 18, 2004 12:52 pm
You tapped it into the #1 runner just before the collector on the manifold, right?
If so, you want to tune so you're right at about 900 deg. celsius (~1650 fahrenheit), at the END of a 3rd or 4th gear pull.
The reason I don't like guess-o-meter gauges is the fact that the EGT only goes up to 1600. Basically, you want it to be hitting 1600 just before the top of 3rd or 4th gear (assuming you're doing a full throttle pull).
EGT's are really a relative tuning tool; pay attention and notice what the EGT's are on your car @ part throttle cruises, full throttle blasts, etc. If you ever notice it's reading hotter/colder than it should be, or it's climbing much faster than normal, you should pay attention and see if something is wrong.
~matt
