Egt
slw240sx
Car: 1990 Ca18det 240sx Hatch
ok so i have my gauge installed and working, now what are the normal EGTs at idle and what is too high when pushing the car.... what is normal ?
slw240sx
bump i need this help too... what are normal EGT and whats too hot!!!! anyone anyone ....
slw240sx
bump ... also what shoul EGT be at idle and at WOT with say 6psi or 10psi???? cmmon someone has to know it ... Mad i know you have EGTs on your CA
themadscientist
No engine in the car but I have one in my Skyline.
Just sitting at idle it hangs between 300-500 degrees Celsius
cruising at part throttle i can go up to around 700 dgrees Celsius
Under full boost on long pulls @ about 12PSI it can swing up as high as 1000 dgrees Celsius.
Get an air fuel meter too, it's better IMO.Ex Temp(good) A/F(better)Both(best)
slw240sx
well mad i have both as of yesterday... but i cant get the AF to work its a cheapo but should atleast work... i think i have the o2 sensor hooked up wrong .... has anyone else ever mounted their AF in the center of the steering wheel where the horn button is supposed to be?? looks rather cool and its right there .....
themadscientist
do that shiznit, that would be hella cool. My night school ebonics classes are paying off, word.
Autometer disco gauge?
slw240sx
sunpro 25$ with bar type l.e.d's
themadscientist
I've had no experience with that one. What does it wire up like, Ig hot, Ground, Signal?
slw240sx
yeah hot wire is red, ground black, signal green... i dont think my O2 is hooked up right ... see when i got it the harness was broken and the wires mixed up i think i know whats the signal wire but the ground and hot wire i dont .. also i dont know which wire on the O2 is hot ground or signal, it has two white and one black.....
float_6969
The Black is probablly the signal. The 2 whites are probabally for the O2 heater. The way to check would be to let the car cool completely down. (let is set overnight) Then hook a voltmeter up to the 2 white wires and turn the igntion to the "on" position (don't start it) When you do that, you should get 12V going through it. One of the white wires should have a stripe of somesort on it. That one will be the positive and the plain white wire will be the negative. That could be wrong, but that's how it usually works.
