EGT sensor for rb26dett
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Hey guys,
for some reason, the egt sensor on my car is about 2 feet down the downpipe. I was told it is useless in that place, and it should be right outside the exhaust port.
Your thoughts, please.
I don't want to relocate it and find out it is something particular to this motor.
Joe
you have an aftermarket EGT sensor?
mattblancarte
i dunno if it's aftermarket. any way to tell?
Just curious about the recommended location.
Joe
the thing 2 feet from your turbo is your o2 sensor.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
EGT sensors are on the exhaust manifold itself and specifically on the runner pre-turbo. If you really do have an EGT sensor after the turbo, it isn't telling you jack squat in that location.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Your EGT sensor should look like a metal stick L shaped.
A O2 sensor is thick.
Unless you bought a modified motor, your probably thinking about your O2 sensor.
mattblancarte
indeed indeed thanks for the clarification guys. picking up a innovative motorsports wideband kit because the car goes on the dyno this friday. will have vids and pics
kjlindgr
Stock GTR's do have an EGT sensor located about where the passenger seat is.
Darius
Maybe for the R34, but I'm not seeing anything in the R33 manual for one on the RB26. I'm only seeing two O2 sensors.
mattblancarte
from what I understand, if an egt is located that far away from the exhaust port it is 100% useless.
gawdzilla
Car: none
Darius wrote:Maybe for the R34, but I'm not seeing anything in the R33 manual for one on the RB26. I'm only seeing two O2 sensors.
there is one.. it's called the "exhaust gas temperature sensor" and there is also an "exhaust gas temperature warning lamp" that can be trigged by the ECU. i've never seen this sensor in person so i have no idea where it is or what it looks like.
mattblancarte wrote:from what I understand, if an egt is located that far away from the exhaust port it is 100% useless.
yes, you are right, but people are discussing aftermarket egt sensors that read real time. until you're sure what sensor you have under the car i would not touch it. first of all, does your car even have an egt gauge in it?
Sil240
Post up a pics of it.
mattblancarte
Yep, car has a working egt gauge. The only reason I'm asking about this is because I have the car in right now to have a innovative motorsports wideband sensor and gauge installed, and the master tech (one of the guys that built the Dynocomp STI that battled the Mine's r34 at buttonwillow) noticed the egt sensor was way down the downpipe.
I don't plan on relocating it, was just curious. I always like to double-check what techs tell me.
gawdzilla
Car: none
he is basically right, since egt is a relative reading based on how close your sensor is to the head. i wouldn't be worried about it though, your readings will just read much cooler
neonbomb
Ahhh i miss the days of my 300zx with Dual EGT gauges
