Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Thu Aug 12, 2004 7:40 pm
EGR can have an effect on gas mileage, but it would be very small. In some cases positive, and in some negative. Overall, the thing is that if you remove it without re-tuning the computer, it will expect it to be opening and closing causing a small (very small) amount of confusion for the computer. Its not a big deal either way, but less pollution is always better when it doesn't affect your mileage/power. Leave it unless you absolutely MUST yank it.
As a side note, newer cars don't even have these since the combustion chamber design, fuel computer tuning and 3-way cats eliminate the NOx problem altogether. I wouldn't be surprised if you could run cleaner by stripping it off, re-tuning the ECU and throwing a good (though pricey) 3-way cat on. Sadly, smog rules don't take this into account and will fail you on a visual..... stupid smog laws.
