EGR Valve
thejfed
Car: 1990 300ZX 2+2
Hey guys,
We have a 1990 300ZX. Mechanic says the EGR valve isn't working. We've heard two different things. One mechanic is telling us that the EGR valve isn't necessary and we should buy the block-off kit since Minnesota doesn't have emissions. Another mechanic tells the EGR valve is necessary.
Can you provide any insight?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Not necessary. Delete that bish with a quickness.
thejfed
Car: 1990 300ZX 2+2
Can you explain why it's not necessary? Again, getting conflicting stuff from "mechanics." Sadly have yet to find a true Z mechanic in MN.
Also, I'm told it's a PITA to get to the EGR valve. Something like 9 hours of total labor start to finish. That sound right?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
http://autos.yahoo.com/maintain/repairq ... 080_1.html
EGR valves help make our air cleaner, reduce the risk of detonation, can leak and are an absolute bear to replace.
thejfed
Car: 1990 300ZX 2+2
Sooo basically if ours isn't working and we are going to do something about it, we should just block it off instead of replacing it. I'm not sure how much I care about clean air with this car considering it gets driven less than 2,000 miles a year.
Z31toZ32
Car: 1999 Infinity QX4
how would your mechanic know that it isn't working? is yours a 96 with odbII? I would just leave it as is until you do some sort of maintenance that requires you to pull the plenum. when you do that, then you can do the official "egr delete" which cleans up a crapload of vacuum lines under the plenum and makes your next plenum pull easy.
A Paratroopers 300zx
Car: 1992 Nissan 300zx Twin Turbo
2004 Toyota MR-S
Here is a link with a ton of info on the EGR valve and delete process:
http://s95014253.onlinehome.us/63104/197828.html
Hope this clears things up a bit!
P.S. On an OBD I system (1990-1995 Z32), there isn't really a way of determining if the actual valve is malfunctioning... unless you pull it and inspect it. Very hard to do with the engine still in the car. Over the years, the valve can become gummed up with carbon and stop working... causing all kinds of issues.
thejfed
Car: 1990 300ZX 2+2
Engine is developing a rough idle. Mechanic determined it's a combination of the 02 sensors being shot and the EGR valve leaking. While he isn't a dedicated Z mechanic, he's pretty good. I trust him.
thejfed
Car: 1990 300ZX 2+2
After reading that article, I'm even more confident. My mechanic said basically the same thing. He informed me he could do it with just the upper plenum pulled, but it'll be a PITA. But at this point, it's becoming necessary.
Z31toZ32
just because you trust him doesn't mean he is making the right call. these cars are tricky... you need to find a z guy.
anyway, if the car is still at the shop, tell him to ohm the injectors. it doesn't take more than 10 minutes. a rough idle is usually caused by an injector or two going out. here is a guide: http://www.twinturbo.net/nissan/300zx/F ... ctors.html
thejfed
Car: 1990 300ZX 2+2
It's not currently in the shop but it'll be going back.
I know I need a Z guy...but I've yet to find one in MN. If you can help I'm more than open to finding one I can trust that knows these cars. Will have them check the injectors.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
thejfed wrote:It's not currently in the shop but it'll be going back.
Print these materials, ask your mechanic to read through them and he'll be that much closer to being a Z guy.
http://home.swipnet.se/e-solutions/Vacuumleak.html
http://www.mdsmarthome.com/z/Z%20Tech/Z ... 20Idle.pdf
