jdurrty »
https://forums.nicoclub.com/jdurrty-u147989.html
Fri Feb 26, 2010 9:07 am
I spent the better half of a day tearing my engine bay apart with this same exact problem. The best way to get the egr out is to unbolt the egr valve AND the exhaust tube connected to it from the drivers side exhaust manifold. Once you pull out the egr along with the tube, you can then unbolt the tube from the egr valve. It was the easiest way we found to do it. I can probably get some pictures up if you really need them. But if you are having vacuum issues, there might be several other contributing factors. The whole egr system uses miles of tubing with another solenoid valve located underneath the passenger side intake plenum behind the power steering pump. The problem could be anywhere, this diagram might help
