TDS »
https://forums.nicoclub.com/tds-u28899.html
Wed Apr 02, 2008 1:47 pm
Nissan has a specific block off bolt for that hole. I have two of them; one for that bung that goes to the egr, and one for the bottom bung that goes to the AIV. Otherwise just block them off with any bolt you can screw in. You will still have the egr pipe hanging there and you should block that off too unless you remove it with the EGR valve that is behind the intake manifold.
Plugged and EGR removed:
Bottom bung that leads to AIV (hard to see):
Modified by TDS at 7:01 PM 4/2/2008
Modified by TDS at 7:03 PM 4/2/2008
Modified by TDS at 7:04 PM 4/2/2008
