Kardineedu wrote:I dont have a check engine light either and what is CEL?
you just said what it is, C.E.L. Check Engine Light
oops so there 4 bolts my bad well if the flat ones keeping it on take it off, if its in your way to remove the valve take it off. if you don't have too dont.also there should be a metal line coming from the header connected to it as well yoru gonna have to take that off as well
