EGR Vacuum line on SOHC 2.4L
WhiteKnight
Car: Nissan 240SX
My top hose came off the engine and I can't see where it went.
Where does the EGR top vacuum line go to?
The FSM shows it goes to 15a and I can't tell what that is. Looks like the back of the fuel rail. Anyone know?
Johnnie
Car: 1990 240sx Fastback
any chance you could upload a picture of what your engine looks like with this hose missing? I just took a quick look at my engine and it looks like that hose connects to some vacuum lines behind the intake manifold. I would venture to say that the hose connects to either vacuum line 2 or 3 in the vacuum tubes-1 diagram on the bottom right. In the engine, they are located directly left of the intake manifold
Johnnie
my bad, it doesn't connect to the "2 or 3" on the diagram, as they are both located on the back side of the head, on the firewall. in the bottom left corner of the bottom diagram, with the labeled intake manifold collector, and numbers 20, 12 and 8, on the top left there are two male end vacuum hose outlets, i believe it connects to one of those. and I think it's the top one. BUT, I'm not entirely sure, considering I really haven't a clue on which hose is broken in your car.
WhiteKnight
Car: Nissan 240SX
I found it.......the red hose from the bpt connects to the yellow hose going to the EGR
