wayne_95 »
https://forums.nicoclub.com/wayne-95-u50760.html
Sat Dec 16, 2006 6:10 pm
My benefit of cleaning the EGR tubes is to pass state inspection and my car (140,000 miles) was passed yesterday. The Check Engine Light (CEL) is off now.Thanks Littlewillie and Yodawill2000. 1993TanJ30, you can wait until CEL code 32 appears or valve cover gasket leak oil. When you do it, I recommend you to do both and also replace the PCV valves and hoses and spark plugs (if your spark plugs have about 60,000 miles). I wish I did the same as Littlewillie did. He removed the plenum (intake manifold) so he has more room to acess to the EGR valve and easy to remove the tubes. I took a short cut by just removed the end of EGR tube under the plenum. It was quick but the tubes were bent. This made it impossible for me to push the tubes back into the holes, even I followed Littlewillie's technics. So I have to unbolt the tube ends at the EGR valve, remove the tubes and straight them until I able to put them back. This took more time than it would if I remove the plenum.Anyway, I glad I was able to do it and learn some experience. The car run great and idle smooth with the new PCV valves, new front struts, new timing belt, new front and rear seals.
