EGR Tube Question
Doya
Car: '95 240sx KA-T
So, I recently bought a 4-1 racing header(eBay knockoff), for my 95 240. The problem is, I can't get my EGR Tube to unscrew from the old manifold, because I rounded the nut off trying to get it off with a pair of channel locks. My question is, can I just cut the EGR Tube off from the old header and then plug it some how?
Matej
Yes.
Doya
Car: '95 240sx KA-T
Just yes? Could someone explain why it is ok to do that?
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
insert a nickel into the header hole before rethreading the egr tube back on. If you cut it then the gasses wont escape through the cut tube.
It will not function properly if you cut the tube and leave the hole open. You'll run rich and have a major exhaust leak. Just bend the tube so it meets up with the threads and thread the thing in there.
zer0c123
Car: 1993 Nissan 240SX Hatch
get a an assortment of wrenches and use PB before you go at it. I think I used an adjustable open ended wrench.
ZOMG.SR20
Car: 1990 s13
dynamite lots of dynamite
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Don't you need to take the manifold off the plug it with the nickel? I double this guy wants to do that.
What I did for a temporary fix was cut it and then put a high temp hose on one end and plug it with a bolt on the other
Rigged up much? Yup. Better then a loud a** exhaust leak? Yup.
Otherwise unless you have the intake manifold off...your kinda in a pickle.
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
use WD-40 and a lot of heat,..>
Doya
Car: '95 240sx KA-T
Thanks for the help everyone. I just decided to do what S13xCrazy said. I cut the EGR tube, took the old header off and got the other half out from the old manifold, threaded it into the new header, and then used some scrap hose to clamp on each side. I was out til' 1:00 doing that in the rain last night, don't feel to good now
