:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri Feb 04, 2005 8:21 am
EGR throws random codes...reset it, and if it's not back within a few miles, forget about it.
But to answer your question, it's located between the #2 and #3 intake runner, on the lower half of the intake manifold. Looks like a bolt with two wires coming out of the top...
Anyway, it throws that code when the ECU does a quick check to see if things are operating normally...and it WILL throw false codes. I'll bet everything is just fine...
Just reset and forget, for now...
- Brian
