left channel audio »
https://forums.nicoclub.com/left-channel-audio-u29171.html
Sat Jun 25, 2005 5:41 am
92 ka24de calif model
when i do the test on the temp sensor.. i have 0 volts all the time the continuity from the sensor plug to the ecu is good.... the other wire on the sensor is the (-) or ground for the sensor.. and it says that the voltage should be below 4.5 volts at idle... im sure that doesnt mean 0 all the time .
also this sensor is about 2 1/2 inches long looks like a hexagon... a 19mm took it off hella easy to get to.. right on the back of the intake mani
when i hit the throttle it doesnt change. so is there a prob. with the sensor or a relay that supplies the power to the sensor????? btw that ecu is good i took it out of my buddies car and his car just passed smog.. also no cel ???????? i tested the egr,bpt,and the 2 solenoids on the back of the head.. all are good..
the way i understand it is the egr temp sensor sends a signal to the ecu to turn on the egr valve??????? by temp and backpressure???? well any suggestions would be very helpfull..... car has failed smog twice.. this last time everything was ok except nox... at 15mph its 1775 and at 25 its at 1574.. so needless to say i need to lose alot of nox... brand new cat back
