egr
mean green s14
Car: driving like a retard
was wondering if it would hurt to leave my egr tube open istead of screwing it into the exhuast manifold or header. i think id like to plug the header and leave the egr tube open , so it doesnt suck in hot air , is it bad to leave the egr tube open?
NISTECH
yes if the other end(egr valve) is still functional. every time it operates you will have a huge vaccum leak. disconnect the vaccum line to the egr to stop it from opening. but be aware this will trigger a check engine light.
mean green s14
will disconnecting the vacum line to the ger make it run any different? im installing a turbo kit and would rather just elemenate the ger valve altogether! is this ok
NISTECH
yes there is minimal a/f ratio changes when egr and evap operate. but may not be enough of a change with the turbo installed to physically notice it.
mean green s14
how do i disconnect the egr?
NISTECH
pull the vaccum line off it
mean green s14
its located behind the eninge up agaisnt the firewall side right?
NISTECH
yes passenger side of engine on the back of the intake manifold.
