EGR solenoid valve missing?
RemoGaggi
Car: 2000 Frontier Crew Cab 4x4
I have a California model 2000 Frontier Crew Cab 6 cyl 4X4. While inspecting the vacuum lines today, I noticed that I don't have an EGR Solenoid Valve nor the lines connected to it. Does anyone know if the California models are not equipped with this? Thanks.
[URL=https://forum-attachments.sfo2.di ... .png[/img][/url]
katillidie
Car: 1990 infinity m30
93 s13 coupe vq35hr swapped
96 s14
2003 m45
2000 frontier
is the cel on? if not dont worry about it
Q451990
EGR usually isn't a CEL item... maybe it was by 2000?
Does the valve open when you rev the engine? You should be able to fee the bottom of it lift and flutter a little at about 2000 RPM.
Heath
katillidie
96 s14
2003 m45
2000 frontier
Q451990 wrote:EGR usually isn't a CEL item... maybe it was by 2000?
Heath
u are incorrect! the egr is definitely a cel item... not for the function of the egr but the egr temp sensor... if the temp sensor does not read the correct temp of incoming egr gas's it throws a code.. so if the egr is not working properly the temp sensor is not reading correctly and throws a code.... this occurs on all nissan vehicles starting in 96 and some pre 96... i know this for a fact because i always delete the egr and until recently i wasn't able to get the light out... but i now know a trick to delete egr and turn off the cel..
Q451990
katillidie wrote:u are incorrect! the egr is definitely a cel item... not for the function of the egr but the egr temp sensor... if the temp sensor does not read the correct temp of incoming egr gas's it throws a code.. so if the egr is not working properly the temp sensor is not reading correctly and throws a code.... this occurs on all nissan vehicles starting in 96 and some pre 96... i know this for a fact because i always delete the egr and until recently i wasn't able to get the light out... but i now know a trick to delete egr and turn off the cel..
Yep... thinking old Q, not "newer" truck.
gullymonster
Car: 91 d21
Whats the trick?
