EGR resistor location
MarkRipoll
Car: 1995 240sx
Where do you place the egr resistor for the egr resistor mod, i have searched.
Thanks
TDS
Car: 2008 G35
I made a thread on this. Just unplug the sensor from the harness and cut the wire from the sensor near the EGR. If you want a cleaner look you can trace the wire to the ecu and do it closer to there. At first I just spliced the wires to the resistor but that didn't work. Then I got a solder and that worked. Read through this:
zerothread?id=312702
MarkRipoll
Car: 1995 240sx
Yes i saw that thread but where in location to the engine is the plug where i place the resistor?
Thanks soo much
Nastjuid
Car: S13 KA24DE
Edit: There's a good reason why that sensor is there to begin with. The part is $125 new, and requires a 14mm sensor socket which could be made with a grinder to remove/install. I bet you could get a working one for under $20 at a local junk yard.
That sensor is intended to go off when the EGR system fails, letting you know that you're constantly recirculating -- or not recirculating exhaust gases. Bypassing it like this could make it difficult to diagnose idle and bogging issues.
That said...
You have a big fat connector right above your throttle body. You can trace the harness under the intake manifold, and just before it disappears under the bottom, it should branch off and have a connector.
That should go to a sensor that is bolted down to the top of the lower plenum between the second and third runners. You may need to move the fuel delivery and return lines to get at it.
A real clean job would be done as described above.
To more easily track down where things are, I suggest grabbing a Factory Service Manual (FSM).
Modified by Nastjuid at 10:02 PM 10/7/2008
