EGR removal
welderguy
Car: S14
Hi this is my first post here, I have a 95 240sx. I have removed the EGR system from my engine (one small step towards orginizing things) Now I am of course throwing code 105 (EGR and canister solenoid). I would apriciat it if any one could tell me what Reister I need to put in place of the EGR senser to eliminate this code.
S13ChucKAT
Car: asd
.....ummm.. there is no resistor you can put in.. sorry.. The car reads the temperature of the combustion chamber through exhaust gas's, and the first O2 sensor is the determining factor.. Unless you make a controllable O2 sim.. i suggest removing your CEL bulb
welderguy
Car: S14
Thank you for your reply I am still learning. I thought that the O2 sensor detected the amount of oxygen in the exaust gas compared to the outside air. Doesent the EGR & canister control solenoid valve enter the voltage signal to the ECM?
JPG0511
Car: 1993 240sx fastback
i read on this site about a resistor for that. i dont rember where it was but just do a search for egr and you will find it.
