I think you mean 100ohm... A 100W[att] resistor is one capable of high power. The folks at radioshack would be lost...frapjap wrote:...and get a 100w (i think) resistor from radioshack...
i did the same thing on my 89, but instead of crushing the egr or capping it i ran a heater hose and T into PCV hose at the intake pipe, after the MAF so that way its metered cool air going into the Cyl when it opens. didnt see again nor a Problem. ill probably do the same for my 90.eddiec wrote:i disabled it when i installed hotshot header on my 91. welded the header bung closed. i had to cut the old egr tube with mr sawzall. then crushed the end and sealed w/ lots of jb weld. ghetto, but no codes.
